Once you've got a system up and running and one drive goes bad or has an issue due to bad sectors or what-have-you, how do you manage these drives?
For example, if one of the drives wouldn't cause windows to boot, but unplugging one of them does allow windows to boot. What do you do to that other drive to restore it to it's proper place in the mirror?
EDIT:
At boot up, in the raid config, there is the option to rebuild. Which drive do I select the rebuild option on? Or is it just in general/overall, that the command isn't being drive specific?
In windows I see that both drives are labeled as basic, I can just change them to dynamic and put the mirror back together that way right?
I am confused as to which option I should use. Any benefits cons?
EDIT:
