How Far Can i push it safely
Avalanche
today i went out and bought the visiontek 6565 geforce 3 ti 200, i wanna know how far (safely) i can push this card...thnx in advance, and oh yeah where was that 30 dollar rebate?
CrackedSKull
"The Southland" California
well i don't have advice for that card, but normally if you push it just a couple mhz at a time, it'll become unstable and you'll know to back down, because it might get damage if you keep going higher after it is unstable. Run intense video programs or games test stability.(or 3dmarks, might as well get bench at same time right?)
lee
check my sig - they'll go higher but its a safe bet to start from here................
A
Avalanche
hmm i got stock cooling other than the fact that i artic silvered it...so i can get to 220 at minimum huh
wildone
Senior Member
TN
Anyone else noticed this ,I can run 3d mark at 233/533 @150 fsb ,and I can run any game I have at higher clocks with no problem ,but if I go higher then that and try to bench ,3d mark always locks ,I think 3dmark2k1 is a very good stress test.
wildone
Kato
Addicted Tweaker
Toronto, Canada
well, every card is different, your card may/may not be pushed futher than ours. you just have to keep pushing it, keep running graphic stress test, and watch your temp carefully. if you system starts to freeze or become unstable, then you know whats your card limit is with the cooling you have. from that you can upgrade your cooling gear, and push more. this is how we all do it.
have fun!!!:D
