How Fast can u go on a locked xp1800+
Lord Moreira
Banned till 9/16/03
U.S
Using the MSIKT266Pro-Ru and a locked xp1800+ how fast have u gone stable?
And could u tell us ur bios settings please :)?
Cooling is not a issue Cpu-33C Case-28C (Air)
All Vantec Stealth Fans:D except HSFan
Thanks
DaddyB
Toronto, Canada
Well without knowing the stepping of the CPU I would say the most you can hope for is about 1750mhz, a lot of people cant make it that far. That would be about 150 FSB on the default multiplier (assuming you are going to be using 1.85V).
I have a different MoBo but I used to have the 6cu (not the +, mine was only 4500RPM) and it was stable at 150FSB but quite warm. My stepping is AGNGA "Y", if you have a newer stepping then that you might be able to take it a bit higher but 1800s arent known for their OCing abilities.
Lord Moreira
Lord Moreira
Banned till 9/16/03
U.S
Thanks
I'll check the stepping soon as my 60\80mm adapter gets here.
Again thanks but i don't think i go that high stable :(
Let me try it with those numbers
Worse comes to worse i'll just flash :D
Later
