seal said:
Im on 185 x 10.5 = 1942.5MHz. I'm having a LOT of trouble getting any further.
vcore = 1.725
vdimm = 2.75
AIRGA0233RPBW
9
(what do all those numbers mean!? - especially the RPBW and the first number of the next line)
What are your voltages?
Seal
Voltage settings
[email protected]
[email protected]
[email protected]
as far as i know "02" is the year an "33" is the week
"9" is said to be a faily good overclocker which mine is to.
as far as those numbers go heres a borrowed line from da
"Coolest
AXxx00 means you got AthlonXP w/ PR of xx00+.
D, unsure, might be package type (Organic packaging).
M means the vcore, S = 1.5, U = 1.6, P = 1.7, M = 1.75, N = 1.8
S means the max case temp (b4 the CPU begins its frying), Q = 60, X = 65, R = 70, Y = 75, T = 90, S = 95. I'm not sure about the Q through Y tho, never saw them in use.
3 means the amount of L2 cache the proc will have, 1 = 64KB, 3 = 256KB.
C means the FSB speed, B = 100MHz (200FSB), C = 133MHz (266FSB).
feel free to correct me if im wrong...hope this helps
