- Feb 18, 2002
Hi,
I have a dual boot up Windows XP Pro / Windows Millennium machine.
Although I had similar software installed on both OSs, my XP Pro took twice as long to boot as my Me.
After trying all kinds of tweaks and tricks, this was the only one that really worked:
Windows XP Pro Start Menu > Run... > regedit
go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Session Manager \ Memory Management \ PrefetchParameters
Double click on EnablePrefetcher on the right side of the window
(It's most likely set to 3).
Boot up time was reduced by 50% when this value was set to 1 for me (!!)
Others say setting of 5 works best for them. Only way to tell is by timing the boot up.
Anyone else care to test this and see?
My Windows XP Pro now boots faster than my Millennium which (measuring from the dual boot screen, after HDs etc. have been detected) boots at 29 seconds to task bar and 44 seconds to full usable desktop.
EDIT:
The 50% difference turns out was only with my old Palomino CPU, SiS motherbaoard and initial Windows XP Pro release.
Now that I use Windows XP Pro SP1 with all the latest updates + heavily overclocked Barton and nForce2 motherbaord, the differernce is "only" 4-5 seconds.
Other people in this thread so far reported the following
3 people: Faster at setting 1 when compared to setting 3.
2 people: No or negligable difference.
1 person: Messed up his Windows installation (?, did you try simply booting into safe mode and changing the setting back to 3?)
Please post chipset, CPU and Windows XP and service pack version if you try this... also how many PCI cards you have...
EDIT:
