i just finished my first water setup and my max temp is 40C under prime95 torture test. is this good??? lemme kno....my panflo 120mm fan makes lots of noise....i might have to get those rubber things to reduce vibration.....
its the panaflo L model. L= low i got a maze3, eheim 1048, DD gf3 waterblock, black ice pro radiator and i made my own res. all 1/2 fittings....the fan noise is from the vibration i think.....
How close is your fan to the radiator? Also, are you using a shroud on your fan?
If your fan is too close to the radiator you will generate a lot of noise. If you don't have a shroud try experimenting with some cardboard and tape to work out the best distance to set the fan from the rad - start at about half an inch away and keep going back until you find the optimum distance (make sure you give the system time to stabilise on each test).
