How long a XP1800 lasts with the Vcore @ 1.85?
Gilgamesh
Norman, OK
??? i would like to know how long a cpu last with that kind of voltage and proper cooling because i don't want to buy a cpu everyweek.
Thx
nikhsub1
Unoriginal Macho Moderator
Los Angeles
Your CPU will last just as long at 1.85 as it will at 1.75. It will last longer than you will want to use it.
muddocktor
Retired
New Iberia, LA
You shouldn't have any problems at 1.85 volts as long as your keep the heat under control with a good cooling solution for your cpu, be it air or water cooled.
WyrmMaster
I'm a little teapot Senior
Montana, USA
Voltage does not kill, Heat kills. Its that simple. If you keep if cool then the voltage wont hurt it. This ofcourse does not apply to hooking jumpercables to your CPU, but within reason just keep the temps down.
