Unique (Mar 11, 2001 01:55 a.m.):
Subject says it all.
Just wanna know how many fans i can run. Was gonna have 7 80 mm fans total. is that to much? or no?
DonSandro (Mar 11, 2001 03:51 p.m.):
there is also a 650 watt Powers supply somewhere on the maket, but the prob. is i don't remember where. Try www.plycon.com. Ohh wait one sec....
here is is:
go there and they're reviewing it.
But that just might be a little to much for you.
The Don
Nagorak (Mar 11, 2001 11:40 p.m.):
Just want to know how many fans I can run. Was going to have 7 80 mm fans total. is that to much? or no?
7 80mm fans is inefficient and I'd advise against it. You can move the same amount of air for half the noise by using fewer 120mm or 92mm fans instead.
