how many clients/pc's can be connected to Win 7 Pro?
dito
Vacaville, CA
I am using XP home and have a total of 6 computers connected in a wired ethernet network. i need one more, but when i try to connect it says i have reached the maximum allowed computers connected to the network. does anyone know what the limit is for Win7 Pro? I only need one more and it is worth it to go to Win 7 (which I use on my personal network)just for this. Thanks for your help!
dito
dito
Vacaville, CA
i forgot, i also have a network printer attached so it's 7 total on XP Home, i need one more to make it 8. Anyone know if this will work on Win 7 Pro? or even XP Pro?
Ben333
Folding for Team 32!
You talking about a limit of ICS clients? I didn't even know there was one... And I think windows shares (files) are limited to 10 clients. What limit are you talking about though?
dito
dito
Vacaville, CA
um, ok, i'm not sure if im using the correct terminology. i have file sharing on a network, i have 6 pc's and a printer. i need 7 pc's and a printer on a network. only 7 total will work on xp home, was considering going to Win 7 Pro since i like it, especially if it will handle 8 total file sharing "ports"
dito
dito
Vacaville, CA
I built the pc with Win 7 pro, not sure what the limit is but 7 pc's and a printer DO WORK sharing files from it. I guess there is no limit on how many pc's you can have on a network, but the limit is how many can access a specific pc. Win 7 Pro solved my problem, so all is good...
Hipcrostino
Canberra, Australia
it'll be some limit built into XP home now doubt. There should be no limits on XP pro or vista/7 pro either as they are for corporate enviroments with 1000s of computers on the same network (well practically as subnets allow)
Ben333
I think XP Pro has a limit of ten simultaneous connections. Otherwise, how would Microsoft milk that extra money outta small businesses? ;) I'm surprised that a home version would be limited to LESS than ten though, or any version for that matter.
