- Jul 2, 2003
- Canada
I just picked up an old P3 ATX tower today and finished painting the chasis and all that good stuff. Now that I've started putting in the hardware I noticed that the power supply sits in front of the CPU socket. The PSU sits sideways against the outside of the case with the mobo behind it.
I had planning to put a decent sized heatsink on there that I had kicking around. However the fan would be right up against the bottom of the PSU. So I tried putting the stock heatsink and fan on, and that only gave me about 1cm of clearance at the most.
The mobo is a gigabyte GA-7VM400AMF micro ATX board with a VIA chipset, so at most I could have overclocked the 2500+ I'm putting on it up to 180mhz. With a stock fan though I'm not sure how far I can push it. As well the issue of the HSF clearance could be a problem. What do you guys think?
