Build a shroud. You're wasting real estate by not have air blowing through all of the rad.
I like the big fan idea, just use all of it.
It would be interesting to see temp differences between that and 9 120mm fans. I see a lot of wasted rad space that will not be getting airflow with that setup.
Maybe consider building a shroud so that the fan sits back from the radiator face and can pressurize the entire fin bed.
--Update--
Wow am I slow to type today
More surface area always make s more of a difference than more CFM.at 2000cfm, it literally makes no difference. lol
I assume you are not too worried about the noise level?
So can it handle things?
I'm curious how were you able to mount it on there? I see some of the screw holes being over the fins and chambers.
it doesnt mount with any screws. it uses like a sprung zip tie type mechanism to clampis through the core. this rad's fins are very wide, just wide enough to fit the ties through. if you look at approximately the 2/4/8/10 o'clock positions around the fan, those are the "clamps". back side is a wide/flat base, cushion pad, core, cushion pad, spring, fan mount, retaining clip.
oh, for gawd sakes, just go 4x180 or 9x120 either way it'a way cool, I can even run mine passive with an 8350 at 5.0+, for a while.
I am running the MO-RA3 with the 4 180mm setup running the Silverstone SST-AP182 Air Penetrators, they come with adjustable speed controllers and they flat rock!
They provide the best of both worlds either extremely quiet or when more is needed they'll crank up to impressive levels.
http://www.performance-pcs.com/silv...180mm-case-fan-w-adustable-speed-control.html
This is not your regular 180mm cooling fan and it does everything advertised and is the best money I've ever spent on a 180mm fan, many others fell short but this does not.
As far as the MO-RA handling everything you listed I'll say as long as you don't plan to seriously OC those CPUS.
I run mine on a single Gigabyte Aorus GTX 1080Ti and it's load temperature is about 30c. at 23c ambient.
IMO it is one of the best radiators money can buy I've had mine in service now about 5 years.
Trust me, you get what you pay for.
For the most part that is correct but the Silverstone SST-AP182 is a different animal. http://www.performance-pcs.com/silv...180mm-case-fan-w-adustable-speed-control.html
At 2000 RPM they produce 170cfm and 6.1 static pressure and are adjustable from 500rpm to 2000rpm.
