How much will this help?
rack04
Houston, TX
Current HSF:
Vantec Aeroflow VA4-C7040
YS Tech TMD fan
5600RPM, 35.5CFM, 38dBA
Vantec thermal paste
Idle 42 degrees C
Load 48 degrees C
New HSF:
Thermalright SP-97
92mm Panaflo H1B fan
2850RPM, 56.8CFM, 35dBA
Arctic Silver 5 thermal paste
Idle ?
Load ?
This HSF will be mounted on my 1.33ghz T-bird until I upgrade in a week or two to a 2400+ Mobile. Thanks.
rack04
rack04
Houston, TX
dicecca112 said:
hard to tell what is your ambient temp and your case temp?
The ambient temp of the case according to MBM5 is approximatly 32-34 degrees celcius.
Radical
CA
It's hard to tell you exactly what your new temps with the SP-97 will be, but they will be better than they were with your old Aeroflow by at least 3 to 4 degrees.
Jimmy53
Virginia
I am waiting on one too. My thermaltake just isn't cutting it so I had to beef it up. Too lazy to wait for the SP120 anyways. I have clock multipliers to reach here...
