CandymanCan
Disabled
- Aug 14, 2003
- Woodbridge, Va
How stable or youre voltage Lines on the Antec 550 truecontrol ??
I cant afford a PC power 510 psu for $170 so i need to go the alternative.
I want a a good quality power supply that has pretty strong line and wont up and down like crazy on me. What psu would u recomend for under $130, i also want a psu that will handle high voltages and heavy overclocking.
Mu current 500watt psu, the 3.3v line is starting to jump from 3.50 to 3.10 to 3.20 to 3.40, the Line graph i have on Seriuz samerize which will go up and down depeding if the voltage goes up and down is like Al jaggy which is showing my 3.3v line i starting to take a dump.
I thought it was the pluggs that were worn out. So i took an old 150 watt psu and pulled some pluggs out on the main connector cut the wires and did the same on my 500 watter to replace all the orange pluggs and the single blue one, i hooked it all back up correctly solderd the wires toegthe, used some electric tape, plugged it up and turned it on, the lines were stable again @ 3.30-3.33, but as soon as started playing a game they went all crazy again, and now even idle it still does this.
I was looking at the Antec 530 truepower in a local store. Can anyone give any info on how this holds out, like what are youre voltage lines idle and what they when on full load. Do they jump up and down like crazy. I really need a new psu soon before my current one frys something.
Also is it tue the Antec 530 truepower has Voltage adjustments that u can do manually, like t ochange the 5v or 12 or something ?
Edit: Ok im talking about the Antec 550 true ontrol sorry for the misunderstanding.
