How to bios flash a nvidia card without floppy? (talking windows 7 + 260gtx)
dofey
Hey, how do i bios flash a video-card without a floppy?
I'm using windows 7.
EvgaP or Rivatuner is not an option, because I can't change the settings the fan speed increase by temprature.
(running at 100% all the time is neither an option due to noise)
D
dofey
Error when saving bios
I get an error while trying to save bios. I've started it both as normal user and with admin rights:
Is there any other program I can use to read bios? (and how?)
:O)
"Data position/lenght out of data bounds"
redduc900
Inactive Moderator
Portland, OR
Why can't you change the fan speed in regards to GPU temperature w/ RT? And in order to use NiBiTor in Win7, you'll probably need to disable UAC first. You can also use NVFlash to save / back up your current BIOS file by typing nvflash --save original.rom (replace original.rom w/ whatever name you want to give the saved BIOS file) at the prompt, after booting directly to a bootable thumb drive.
D
dofey
How do I do that?
