- May 6, 2010
great thread, will be very useful as i am just starting my build!
The media card reader
This is really not a necessity, however connecting your camera via USB could get dangerous if you continue. Taking out the SD card seems safer for most users.
What does that mean?
Lots of work went into this it looks real good
FYI: The 4 pin IDE connectors on the power supply are not called Molex, in fact most likely they are made by Foxconn now not Molex. The are actually just called 4 pin peripheral connectors. Might want to make a note of that(since many people do call them Molex connectors)
By the way, you should really keep your head down if you are trying to get away with something... Logging in from the same PC as Joeteck has logged in from (technology is great), complimenting his knowledge, and you have identical CPU, heatsink, motherboard, and power supply. Sorry if I missed a component, I was just glancing. Anywho, when you are again failing to follow site rules by violating a ban that was imposed upon you - if you want the staff to look the other way, you are going about it all wrong.![]()
