how to create an image of my hd so i can reimage as needed?
login211
Ontario, Canada
just formated/installed xp, all the important stuff has been installed... what can i use to create and image of this so i can always just pop in the cd/dvd and get to this exact setup?
thanks
el
Senior Member
USA Capital
well make a bootable dvd with nero express is the best option. just don't change hardware. A fresh install is probably your best option not the image of your install on DVD.
