How to disable Thermaltake Volcano 7 fan speed control
Diggrr
Underwater Senior Member
Cut the temp bulb off as in the pic, solder the two ends together,and wrap with electric tape/new shrinkwrap.
If you can't solder or don't have the tools to do it, twisting them together works fine. But they must be reliably connected...you don't want the fan to stop working! If you can just cut back the heatshrink tubing from the thermister, then you may have enough bare wire to just twist them without breaking the wires at all.
Then enjoy the new temps!
