How to enable HT 2.6C
V
Voodoo_fx
Wisconsin
its a 400 bus jackass lol, it says C1 revision in Cpu-Z.. and I thought this chipset might support it... just asking to make sure what I thought was right..
jdmcnudgent
tOLEDO, OHIO, the heart of it all!
whoa buddie, slow you roll. its quite obvious that you dont know what your talking about. i am just trying to help. unfortunately, cpu-z may say its a c1, but you need a 3.06 chip or a d1 stepping to have HT.:(
see the little "c" after the 2.4 in my siggy.:D
batboy
Senior Moment
Kansas, USA
Voodoo, flaming people here will get you banned. Your thread title says 2.6C which is a 800 bus HT CPU. Now you're saying it's a 2.6 C1, that's a different critter and that does not have hyperthreading. The C1 is the stepping.
V
Voodoo_fx
Wisconsin
well, in one of my other threads someone said it was a early C stepping.. leading me to believe it was a 2.6C Theres diffrent busses on most of the P4's like the 400, 533, 800 now.. figured it was like AMD releasing same speed chips with diffrent FSB's
batboy
Senior Moment
Kansas, USA
The 2.6C is actually a D1 stepping and using 200 FSB (200 X quad pumped bus = 800 MHz). All of the 800 bus "C" CPUs have hyperthreading. The 2.6 400 bus CPU is indeed a C1 stepping, but but does not have hyperthreading. The only non-800 bus CPU that has HT is the 3.06 533 bus CPU. No 400 bus CPU has HT. Voodoo, I can see where the confusing came from. Just edit your post and take the name calling out and all will be fine, ok?
