Probably CPU or RAM problem? Or even combined CPU + RAM?Well it isn't the GPU problem
Heaven has stutters anyway...In the Heaven benchmark I had them.
Most of the benchmarks are not stuttering except this one.Heaven has stutters anyway...
Again, this one has some stutters/hitches in it. So, I wouldn't use it as a barometer.Most of the benchmarks are not stuttering except this one.
Oh it can. It depends on the game...6 cores can be utilized by some games these days. I wouldn't disable the ecores on that cpu. If you leave them enabled does the stuttering stop? When you look at the task manager, what else is taking up cpu cycles? Post a picture of task manager with that going on....I don't think it is should load up to 100% without the E-Cores...
I set the limit to the 140W, but it can't go above 110W even in the Cinebench.
I'm not playing Minecraft but some people said that I should try it too. So I tried and I see the stutters here too.Post a picture of task manager
I'm pretty sure they are not even close to that. Usually it's about 4gb Vram.You're sure the games aren't close to/breaking 8gb vram?
Yeah. I even not touched the emulators on this PC yet.It happens outside of emulation/mobile game, correct??
As I said, the limit was 65W in BIOS. I changed it to 140W. And the CPU just can't hit the new limit. No throttling at all.When you run cinebench and you see 110w, are there any power limits it's hitting?
check hwinfo and see if any throttling reasons are listed.
Nothing there in-game, thats good, and expected. How about during cinebench as asked?Those screenshots are taken when I played Minecraft
Oh yes, here it is:How about during cinebench as asked?
They both are very similar. Something about 4.2-4.5 mhzAlso, what clocks is it hitting? Gaming? Cinebench?
Actually I've tried this too. It's changed nothing.What if you disable your Anti-virus?
Actually, I had these stutters on Windows 11 and now on Windows 10.Maybe try this?
Any i playMaybe some where you never had these issues?
I've tried these DWM optimizations on both Win 11 and 10, and it makes no impact at all..
I'm at loss too. I'm trying to fix that for almost 2 months now and absolutely nothing helped me.
Can you recommend some games to test out? Maybe some where you never had these issues?
I had these micro stutters even in Terraria, lol!Terraria
~5ghz - It's in the boost mode (for a short time, and i've never seen this boost).CPU should be boosting around 5ghz
These two are what allows your CPU to go "above and beyond" the default, you basically just turned off the turbothe last time i've tried to disable these features:
- Intel SpeedStep
- Intel Speed Shift Technology
but the situation became even worse.
Yea, but i've turned them on then. Without them i had locked 2.6ghz.These two are what allows your CPU to go "above and beyond" the default, you basically just turned off the turbo![]()
I bet you will have them in this game:Any i play
