Its my first thread here, so hallo to everyone
I just received my DUAL Acorp 6A815EPD yesterday. Before that i was using an Abit VP6 with 2 Pentium 3 FCPGA CPU's 700(7x100)@933Mhz. Unfortunately my VP6 died for unknown reason.
SO i decided to get the Dual Acorp and overclock my CPu's on that mobo.
The Cpu's can post fine at 700Mhz but when i set the jumper on the motherboard for 133Mhz FSB, i still get 100Mhz.I think that the motherboard will read the FSB directly from CPU's.
I ' ve read somewhere that i can fool the motherboard to think that i am using 133Mhz CPU with a pin trick.
As i found from web there are 2 pins on the CPU which are responsible for the Proccesors frequency BSEL0 and BSEL1.
SO there are some combinations you can do with these 2 pins in order to get the 133FSB.I found some sites on the WEB but i am not exactly sure what i have to do.
http://www.dualcpu.jp/fcpga-pin.html
http://www.plasma-online.de/english/upgrade/tweak/fixes/fix_p62_100_133.html
PLease give me a hand here
Thanks in Advance
My Rig
Acorp 6A815EPD
2 X Pentium 3 FCPGA 700Mhz
2 X Kingston PC133 Memory
WD 20GB Hard Drive for OS/Apps
Maxtor 80GB Hard Drive for Backup/Downloading
Leadtek Ti4200
Lite-On CDRW 52X
Lite-On DVD 166S
Hitachi 8130 CDROM 16x(very old but still works perfectly)
Enermax 3051 Black Case
350W Unknown PSU
Thanks in Advance
My Rig
Acorp 6A815EPD
Leadtek Ti4200
Lite-On CDRW 52X
Lite-On DVD 166S
350W Unknown PSU
