So as I continue the path for building my latest rig, I want to get some better cooling in my case.
My rig:
AMD 945 chip
ASRock Extreme3
4gigs DDR3 1600 GSKill
Nvidia GTX 260
I have an older gigabyte case. It is a full tower, with a 80mm fan in the front, two 120mm fans in the back (very quiet fans).
I ordered a replacement heatsink for the stock HS fan. Actually, it was given to me. It is a zalman 8700 I believe and plan on putting that on.
With that, I would like to get some better airflow through my system without making my system sound like a jet with all the fans.
With that in mind, anyone have suggestions?
For now, i will be stuck with the case. But perhaps in a month or two, I will replace the case.
Anyone have recommendations?
For the 120mm fans in the back, they are:
(1) 120mm Yate Loon
(1)NEXUS 120MM REAL SILENT CASE FAN
They are blowing the air out the back.
Was thinking of having one blow in and one blow out?
Looking for recommendations to keep things cooler inside.
Perhaps even mounting a fan somewhere in side and aiming it at the GPU and CPU?
THanks.
SEk
My rig:
AMD 945 chip
ASRock Extreme3
Nvidia GTX 260
(1) 120mm Yate Loon
THanks.
SEk
