How To Get URL And Code Again
craigiz1
Pompano Beach, FL
I deleted my email with the url and code for my Boinc account.
How can I get it back? And...doesn't the Boince program remember where to connect to send and recieve Boince w/u's?
Seems dumb that I need to input the info for it to transmit. :eh?:
Thanks.
SunRedRX7
Kenmore, NY
I'm guessing that the method for originally activating your account will also work for retrieving lost account info. Their site is currently not working at the moment, but when its back up this should do it.
Participate In SETI at home BOINC page
http://setiweb.ssl.berkeley.edu/sah_participate.php
There you have the option to create a new account or activate your SETI account. You'll then be sent the url for the SETI boinc project, and your username through email.
JigPu
Inactive Pokémon Moderator
Vancouver, WA
I tried using the activation link when BOINC came online officially, but it didn't work since I had activated a month early durring the leaked announcement. Apparently that link will only work once :-/
If you didn't do anything to your account in BOINC though, the URL and account key should be available in an "account_setiathome.berkeley.edu.xml" (or something like that) file in your BOINC directory.
JigPu
SkyHook
Senior Village Idiot
York, Pennsylvania
JigPu
JigPu is exactly correct, if all went correctly when you "attached" to the SETI project the file "account_setiathome.berkeley.edu.xml" should have been created in your main BOINC folder. This file can be read either with some web browsers or NotePad, One of the first lines contains the URL and the next contains you ID Number. If that file doesn't exist on your machine I must admit to not knowing exactly how to proceed. If you have more than one machine running maybe one of the others has the file in question if the one giving you problem does not, as they should all be the same info.
SkyHook
