- May 15, 2006
- Thread Starter
- #21
That is odd it says it can't open the device. Even if the drive is already partitioned, it shouldn't give that error. But, if you already have the drive partitioned, you can skip that step and go right to the "Manually configure block devices" option and continue as normal. Since you probably won't be wiping your boot partition, you will need to manually add the entry to fstab and configure your bootloader to go the right drive.
