Does your board have a ketmod bios on it? If not, put one on. They're great for P5Q Pros.
My P5Q Pro had no issue with DIce temps.
Be aware that MOSFETs covered in eraser may fry on a SS, not enough cold goes into the board to keep 'em cool.
Generally you don't want to cover the mosfets or chokes.
I've used the liquid electrical tape route quite a bit, its good stuff. Still a pain to clean up, but a little scrubbing, sometimes with a brush and some Laquer thinner, and you can get it all up and pretty much into original condition. But its a pain to put down cleanly, and time consuming. (I have an entire motherboard actually coated in the stuff)
Thanks TsunamiJuan! Thinking of keeping a set of mobos around that will stay waterproofed....older sockets...775, 939...ones I won't use for anything other than phase. If I'm understanding you...it sounds like I'm best off just sticking with eraser.
Ewww...don't cover mosfets or chokes? Guess I went WAYYY too far. See my pic at the bottom of page 1...so I should only cover out as far as the capacitors on those sides?
The mosfets and chokes put off alot of heat under load, and the eraser tends to trap the heat raising them out of their optimum temp ranges.
Theirs nothing wrong with allways ready cold setups or those close to it. Since cold prep is key for sucessful extreme overclocking. However for a phase change setup, aslong as the socket area is insulated and doesnt have gaps in it for air to get through a mild amount of insulation is the way to go. Slapping down Liquid electrical tape just helps with some of the water proofing. You will still want the insulation if its eraser. Frost king, or something else to limit the contact of the outside air on the cold area. Aswell as help help the cold in around the socket. So that the units not trying to cool down the entire room (believe me it will try if it left excessively exposed)
Gotcha...thanks again. On another note....anyone know what kind of starting and/or max voltage to send to the cpu? Also...if someone could confirm that I'm looking at the right ketm bios for my board...that'd be awesome.
So...maybe the problem was the covered chokes and mosfets? Maybe the non-modded bios? Thinking can eliminate the waterproofing and insulation as potential sources of my issue? When I pulled the phase head off....it clearly wasn't fully centered on the cpu and part of it was on the eraser (a very short, thin strip).
Max ever? I think the board caps at 2.05v
Most core2 chips will start loosing clock speed as you increase volts past the ideal point. It's pretty obvious usually.
On phase with core2 chips I always start right around 1.55v. Then move on up to around 1.7v. If it clocks good I stop and save it for ln2. If it doesn't clock good I keep giving it volts
Update- Updated bios, re-did the top and woohoo!!! hehehe
So far, looks like the cpu is fair-to-middlin...looking like 522x9.5 @ 1.58125v. Just can't seem to get it stable at 525 and 1.6v (and that gets to 78C on wprime1024 before crashing)
