- Jan 13, 2014
Hey guys since I started mining a few months back I have gotten to play around with my settings and such. mostly following advice on others then tweaking.
But lately with out change to my raw code I have seen my Rejected % go up like crazy. A month back it was 1-2% now it sits between 8-10%.
what are the variables I have to look at to lower this?
I was looking at the guide for optimizing hash rate from here (OCF) and it seems it would either be voltage or TC or atleast I assume that.
My cards are:
xfx 290 (flashed to 290x) hash rate: 942 OC 868 non oc
powercolor 290 (flashed for stability) 860 OC 830 non oc
Water cooled:
temps 45-57 depending if OCing or not
VRM temps
VRM2 35-38 both cards
VRM1 40's for card2 (fujipoly) - 60's for card 1 (290x) (stock pads)
MSI after burner settings:
+63 mv
1000 core
1500 mem
when at Guiminer Flags same for both just change worker:
I 19,20 (19 for main card 290x)
work 512
TC 32765
Vectors 1
GPU threats 1
lookup gap2
-g 1
clock 1000
mem 1500
for CGMiner:
work 256 (if i go 512 it crashes)
-q
--no restart
-d 0,1
clock 1000
mem 1500
TC 32765
Note If I run w/o over clocking I jsut change mem to 1250 but they failure rate is similar. Is it worth the +63mv for the small Hash increase (approx 100 total)?
http://www.overclockers.com/forums/showthread.php?t=742599
My cards are:
Water cooled:
VRM temps
+63 mv
1000 core
1500 mem
work 512
TC 32765
Vectors 1
GPU threats 1
lookup gap2
-g 1
clock 1000
mem 1500
for CGMiner:
-q
--no restart
-d 0,1
clock 1000
mem 1500
TC 32765
