How to make 8kha+ stable at 200 mhz?
holst has said that 8kha+ is stable around 200 mhz for system speed and also many 8kha+ owner did achieve like those crazy system speed like 185 mhz and over
My question is how? what was the trick?
I mean at 200mhz system bus speed, the ddr is running at 400mhz, AGP bus is running at 100 mhz and also PCI bus is running at 50 mhz. How to make the system stable when those speed is way out of the spec? I am having problem just to go over 154? I need help...
- Faster DDR like PC 3200 and PC 3500?
- Increase Vcore to 1.85 or higher? Vdmm to 3.0v or higher?
- Stable and good Power Supply?
- Lower the mutliplier?
- Change the DDR setting to slowest?
- Force ATA 66 on all the HD to prevent HD corruption?
- using ATA controller card that support 66mhz pci?
