Hi there,
I've a Asus P9X79 LGA2011 board which is causing some problems.
The computer turns on and after a second suddenly turns off. Then turning itself on again and booting to bios with a message like "ASUS anti surge...."
The voltages shown are way out of range.
vcore 1,7V (!)
3,3V rails is showing 3,6V
5V rail is showing 10,5V
12V rail is showing 24,1V
I'm guessing, if this would be the real values, everything would be dead
A BIOS update has been performed. A BIOS reset has been made. Still no luck :-(
The PSU is a bequiet Dark Power Pro 550 Watt. I've checked the PSU with a tester - all voltages are within the specification.
Nevertheless, I attached another PSU to the board - with the same result.
Obviously, there is a problem reading the values from the sensors.
Can anyone tell me please if it's possible to measure the voltages directly on the board? - and if so: where?
I've attached a bunch of high-res images of the board.
Thanks and best regards
vcore 1,7V (!)
