- Jun 19, 2001
I read somewhere about how someone would like a way to detect if the pump was working or not.
One way would be buying a analog(or digital) Amp meter, and hooking it up with the waterpumps powercord. Just Calculate how many amps the pump will use, and get a meter according to that. If the pump dies, it wont draw any amps at all, or it will draw a SHITLOAd of amps... depending of the nature of the fault. Anyway, if you had a digital amp meter, you could build a circuit to check if it worked, and if it doesn't then just shut the pc off. I am sure this can be implented. Any comments?
