CAPiTA said:EDIT # 2: Or would I be better off with this?
http://www.dangerden.com/mall/Radiators/heatercore.asp (double)
QUOTE]
That heater core would peform better than the bix
toorude said:ukdan, although its more practical to just drill and mount, I have friends that have used epoxy on flat head screws then mounted the fans and such to it and taped it all together to get a firm hold, then after the epoxy sets the screws will forever be one with your case, cept no screw holes its actually kinda neat.
