OK, I know there is some sort of Console feature that can be opened for Folding, im using the OneClick folding app. and id like to know how i can open the Console to see what exactly is up. TIA
you dont need to open the console with the one click, ever. Just open you FAHlog.txt in the fah directory to see what is going on, the log is the same as you would see with the console.
If you want to use the config utility, just create a short cut and put a -configonly flag after the console exe path. That will let you configure it without starting the client.
