How to overclock A7M266
Eil Atan
Is there any way to change the multiplier on my Asus A7M266 motherboard? The multiplier in the bios is 10.5x and it is grayed out... I should need to up the multiplier to overclock, right? Also, how about changing the voltage settings?
ok all before you tell me i scrolled down and read about how you need to add the dip switch... can do... where can i obtain one of these? also, should i up my power supply, and if so, how much?
it would probably be better to get a better psu, minimum should be 300w. When you raise your fsb you need to raise voltage too. DIP switches are already on your motherboard you just need to switch the spot they are seated in, but on your board unnecessary since your board has sfs (stepless frequency selection). This means your fsb can be increased in 1MHz increments. This is in your bios.
