Are we talking "DRAM Bus Voltage" here? - Minimum is 1.5V on my board....
That would put my QPI/DRAM Core Voltage in the range of 1.1V and 1.9V.... (If I keep my RAM at 1.5V)
Funny enough - In the "description field" on the right side of the screen, it says: QPI/DRAM Core Voltage: Minimum 1.2V, Maximum 1.9V
You guys want me to up the QPI/DRAM Core Voltage???
1.6V !!
Is that nitrogen cooling...
I think that amount of voltage will fry my CPU rather quick.
I could be wrong though!
I'm having "personal issues" going past 1.4V VCore
If the ceiling of the chip is not what's holding you, then yes. Meaning, maybe your particular processor won't do 4.6 with your current cooling method.Increasing Vcore - Is that the only thing that would make the above work for me?
You have thos backwards, Sir.the qpi/dram voltage, if I remember correctly- needs to stay within .5 of your dram voltage
