How to put SPU in coolermaster haf 932 ???
Vasya
Fan up or fan down ?
i got mine like this >
should i turn it with fan up ?
zbo
If its got vents beneath it then allowing it to draw in the cool air will be better for the PSU.
For a moment I thought you were talking about: this
Vasya
Vasya
what do you mean sorry, english not my first language
tinymouse2
Surrey, England
Basic English mode:
On a table that will be fine. If case is on carpet then fan needs to point up.
Hopefully you can understand this and hopefully I haven't made this to simple.
J-O_S-H
England, United Kingdom
does it have feet on it to raise it up off the table?
The case has feet or wheels (depending what you wnat to use) to raise it... the PSU is also raised off the case floor by a vented riser palte... there is plenty of airflow.
As someone else said as long as the tower is on a hard surface it should be fine pointing down.
The HAF 932 has 2 mounts for the PSU...
If it is on a carpet mount the PSU at the top of the case and simply put the blanking plate at the bottom. It is very easy to do this.
