Hey mates, i overclocked my RX 570 8gb with the programm OverdriveNTOOL i put one value way to high and apply it now my GPU is not showing any screen untill it is connected with my motherboard.
After removing the gpu to get a display signal from my cpu or other GPU
(that i put in instead of the rx570) i tried to delete all files of overdriveNTOO. I also tried to go in my bios and hit f9 to reset everthing to default.
How can i fix it? To reset that value that i put to high and crashed.
The problem is after the crash i still have no screen signal from the same GPU...
