- Feb 18, 2002
How can you set CHKDSK to run on all partions ( not just C: ) upon reboot.
C: partiton requires a reboot but others may be run from within Windows XP. What if you wanted to run CHKDSK on all partitions, not just C: upon reboot?
EDIT: Solution for Windows XP below but what about Windows 7?
c627627 said:*********************************************
To schedule CHKDSK on next boot, open any folder on the partition that you wish to check >
My Computer > Right Click on drive partition > Properties > Tools TAB > Check now...
If a folder on this drive is open, you will be given an option to do a scan on next boot.
Repeat for any other partitions that need to be scanned upon reboot.
Reboot and before Windows boots into desktop, chkdsk will commence for all partitions.
