How to stabilize pci-e bus while overclocking?
moheban79
Hi,
I have this old X58 920 D0 rig I'm overclocking. Got it mostly stable at 3.8 ghz except once in a while very rarely my sound card will drop dead and I have to reinstall or re-enable the sound card device. So was wondering where would you bump up the voltage to get devices like a sound card stable?
Thanks
trents
Senior Member
If you back off the overclock a little does the problem disappear? What motherboard are we talking about? Higher end motherboards will generally tolerate higher BCLK/FSB frequencies than bargain basement boards.
M
moheban79
I think if I back off the overclock these symptoms go away. Its an old X58 Evga Classified E759 with a 920 D0 at 3.8ghz. Got the Fsb at 198 mhz and 19 bclk with something like 1.33 v on the cpu and 100+ v vtt volts. Ram is just under 1600mhz as well. As for the exact settings I would have to check and get back to you.
Thanks.
