How to Sync Firefox ONE WAY only
c627627
c(n*199780) Senior Member
Incredibly, Firefox sync master machine *cannot* be set (!)
Therefore your main computer will continuously be overwritten with data from your mobile devices as Firefox sync functions as two-way only.
SOLUTION: Firefox > Tools > Options > Sync > Manage Account > Delete account
Sign up for a new account immediately (you can use the same exact email and password).
Setup what gets synced: Firefox > Tools > Options > Sync >
Tools > Sync Now
Now log in with the same info on your mobile devices and sync them.
After syncing completes, immediately Disconnect your mobile devices [scroll down under where syncing settings are].
For Android devices:
Android Settings > Accounts > Settings > See Auto-sync data needs to be CHECKED for syncing to go through.
I understand that it is useful to have ALL devices be able to add/delete what they want and for all changes to be synced.
But for there not to be an *option* - just an option - to have a master machine from which other devices are synced...? Really Mozilla?
Luckily the above is a true workaround.
Vishera
Who even uses Firefox anymore? I'd say this is a prime example as to why the answer to that question is not very many people. Believe me I used to love it. Over the years I constantly switched between FF and Chrome as every once in a while one would become better than the other. But Mozilla seems to have their heads up their rears or something because it suddenly became, and STAYED, ungodly slow. Nice options for plugins, extensions, and UI customization though.
c627627
c627627
I agree that Firefox requires a lot of modifications and therefore is difficult to use.
But there are no add-ons for any other browser like there are for Firefox, which once modified, is still the best because of those add-ons, not because of Firefox itself.
Janus67
Benching Team Leader
Do you have any examples, c6, for things that there aren't equivalents of on Chrome? I'm sure there's some, but I can't imagine many that hadn't been ported/replicated.
c627627
c627627
Some of my add-ons are available, many (...many) are not on Chrome:
auto_copy_1.0.8.1.xpi
(Selected text is automatically copied to the clipboard.)
https://addons.mozilla.org/en-US/firefox/addon/383
http://autocopy.mozdev.org/
bookmark_favicon_changer_2.25.xpi
(Set bookmark link icons.)
https://sites.google.com/site/sonthakit/bookmarkfaviconchanger
Download Link without corrupt xpi files:
https://www.mediafire.com/folder/p5zci7993vuf7/BookmarkFaviconChanger
chrome_view_0.2.2.1
(Open current page or a selected link in Google Chrome. Set Chrome location in options.)
https://addons.mozilla.org/en-US/firefox/addon/chrome-view/
clonewindow_0.2.9.xpi
(CTRL+N opens a new window with same content. Also an option for New TAB to open with same content.)
http://www.pikey.me.uk/mozilla/?extension=cw
dictionarysearch_45.0.0.xpi
(Looks up a user selected word in an online dictionary.)
https://addons.mozilla.org/en-US/firefox/addon/dictionarysearch/
ESCapeFromThemGIFs_0.1.2
(Pause animated gif's with the ESC key.)
http://updatepack.nl/Firefox/
https://addons.mozilla.org/en-US/firefox/addon/escapefromthemgifs/
findbar_ tweak_2.1.10
(Customize Quick Find toolbar.)
https://addons.mozilla.org/en-US/firefox/addon/findbar-tweak/
flash_control_2.1.4
(Disable/enable flash by clicking in the flash symbol in the middle of the web page.)
https://addons.mozilla.org/en-us/firefox/addon/flash-control/
greasemonkey_3.9
(Customize the way a web page displays or behaves, prevent it from launching prompts at exit.)
https://addons.mozilla.org/en-US/firefox/addon/greasemonkey/
I don't care about cookies_2.5.9.xpi
(Get rid of annoying cookie warnings)
https://addons.mozilla.org/nl/firef...ction_id=6791672f-3882-43b4-bdbe-aea9bf6c0dbd
ie_view_1.5.6.1.xpi
(Open current page or a selected link in Internet Explorer. Set %ProgramFiles%\Internet Explorer\IEXPLORE.EXE as default location in options so that the Add-on can be use by multi-boot systems.)
https://addons.mozilla.org/en-US/firefox/addon/35?id=35&application=firefox
imagezoom_0.6.3.1.xpi
(Zoom in & out of any picture. Also an option to have Image Fit in the right click menu by CHECKing that option in the Zoom Context Menu TAB.)
http://imagezoom.yellowgorilla.net/
last_tab_close_button_0.3.7.1.xpi
(Shows the "Close" button on the last tab in Firefox.)
https://addons.mozilla.org/en-US/firefox/addon/last-tab-close-button/
map_this_0.3.1.1.xpi
(Get a street map or directions to selected text address.)
https://addons.mozilla.org/en-US/firefox/addon/1886
make address bar font size bigger_ 1.3.2.1
https://addons.mozilla.org/en-US/firefox/addon/make-address-bar-font-size-big/
menuedit_1.2.7.xpi
(Edit Firefox right click menus.)
http://menueditor.mozdev.org/
plain_old_favorites_1.3.1
(Use one Favorites folder for both Internet Explorer and Firefox. Do not update this version, follow-up versions have a slight display delay.)
http://www.iosart.com/firefox/plainoldfavorites/
https://addons.mozilla.org/en-US/firefox/addon/668
RightToClick_2.9.6
Stops annoyances such as forbidden right click, forbidden text selection or cascading dialog boxes.
Advanced options > Fetch images gets RightToClick menu button to list only pictures from the displayed page.
https://addons.mozilla.org/en-US/firefox/addon/righttoclick/
toolbar_buttons_1.0.2.xpi
(Additional Firefox buttons, including Minimum Font size.)
http://codefisher.org/toolbar_button/
https://addons.mozilla.org/en-US/firefox/addon/toolbar-buttons/
tweaknetwork_1.8.1.xpi
(Tweak Firefox settings for faster page loading and more simultaneous downloads.)
Firefox > Tools > Tweak Network Settings > OK > Power > OK)
https://addons.mozilla.org/en-US/firefox/addon/327
http://www.bitstorm.org/extensions/tweak/
ublock_origin_1.9.4.xpi
(Ad blocker. Easy on CPU and memory. )
Sometimes you need to do this manually:
Show Dashboard > 3rd-party filters > Update now
and you may need to UNCHECK: EasyPrivacy there.
https://addons.mozilla.org/en-US/firefox/addon/ublock-origin/?src=search
userChromeJS_2.0.xpi
(userChromeJS allows chrome customization so that Menu names can be changed through userChrome.jss text file.)
http://userchromejs.mozdev.org/
mozilla_archive_format_3.1.0.1.xpi
(Save web pages in a single file.)
http://maf.mozdev.org/installation.html
reloadevery_28.0.2
(Reloads webpages every so many seconds or minutes.)
http://reloadevery.mozdev.org/
User Agent Switcher_0.7.3.1.xpi
https://addons.mozilla.org/en-US/firefox/addon/user-agent-switcher/
video_downloadhelper_6.0.0
(As soon as you start the embedded video, right click > DownloadHelper > Media > add the video to download queue)
https://addons.mozilla.org/en-US/firefox/addon/3006
Janus67
Many of those that you listed there are available in chrome.
Greasemonkey = tamper monkey
User Agent Switcher
Ublock Origin
Video Download helper has an equivalent
Reload every exists
Right to click
https://chrome.google.com/webstore/detail/allow-right-click/hompjdfbfmmmgflfjdlnkohcplmboaeo?hl=en
Map this equiv:
https://chrome.google.com/webstore/detail/quick-maps/bgbojmobaekecckmomemopckmeipecij?hl=en
Image zoom or similar:
https://chrome.google.com/webstore/detail/hover-zoom/nonjdcjchghhkdoolnlbekcfllmednbl?hl=en
the list is likely covered.
c627627
c627627
It was easier for me to copy-paste all, but I could have taken the time to go through the list and just mentioned the ones that are not.
Like I said there were many.
The list also has the ones that are available a few of which you found.
Without going into "well what you need that for", just as an example, I've built my Favorites folder since Windows 9x.
When Firefox came out, it used Bookmarks (like Chrome) - however - there was an add-on that lists the physical contents of the Windows Favorites folder right inside Firefox.
So for testing purposes I could still fire up Internet Explorer or Firefox and the Favorites menu would display the same physical location of Windows\Favorites so I never actually switched to Bookmarks but continued to use a custom physical Favorites folder which is displayed simultaneously inside Internet Explorer and Firefox.
Nothing of the sort exists under Chrome.
I could go on, but then we would have to get bogged down is how many of the missing add-ons are enough? For me that number is 1.
If even one add-on from the list is missing, then that's too many. But there is more than one. My list is relatively short. Other people's lists are much bigger.
I also seriously doubt that Chrome would allow the extent of physical modifications that are allowed on Firefox, but I never even thought of that because the functional (as opposed to cosmetic) add-ons weren't there for Chrome and are still not from what I can tell...
I routinely right click on Windows > New > Shortcut and create physical .url shortcuts.
These are stored in Favorites folder as individual files.
There is even an Android add-on to open them:
https://play.google.com/store/apps/details?id=com.zapek.android.stuntzurl
So for me this is one of the most important Add-ons for Firefox:
https://addons.mozilla.org/en-US/firefox/addon/plainoldfavorites/
