i'm not too sure if it's a heat problem. my dilema is that if it IS a heat problem and i get the mobo. i am broke (i'm only 17) if i get the new cooling and it ends up being mobo. den i'm also screwed. my temps (as monitored by an Asus A7V mobo) is:
cpu:
[email protected] [email protected]
mobo: 36 constant
however, one tym, when i took my com outside for a few hours 2 clean it, when i went back inside the house and plugged it in, the temps read
mobo:17
cpu: 27+
even then, it was locking up. so i'm not sure. I'mt not sure if a video card can cause it to lock up tho. my video card temp (monitored by the leadtek winfast geforce2 gts onboard monitoring probe) says the card edge is 53 while the surface is 63. critical temp is 72. so i'm not sure if that might cause lockups. i'm hoping those temp readings are accurate. because i've been told the a7v can b up to 10degrees wrong. if so, might mean that cpu is actually
[email protected] so.. yea.
