how to upgrade bios on msi k7t-pro2/a
Izi G
i have MSI k7T-pro2/a motherboard vit bios ver 2.5
i have downloaded msi power bios (w6339v10b16) and i don't know how to update it. On Msi site writes that you have to use /nbl switch (awfl789.exe /nbl) but i know that you have to use other switches (/py... etc) too. so in which order (is /nbl first or last)
can you please tell me the whole procedure how to upgrade bios that it will 100% work?
Izi G (Jul 18, 2001 02:11 a.m.):
i have downloaded msi power bios (w6339v10b16) and i don't know how to update it. On Msi site writes that you have to use /nbl switch (awfl789.exe /nbl) but i know that you have to use other switcx (/py... etc). so in which order (is /nbl first or last)
can you please tell me the whole procedure hov to upgrade that bios that it will 100% work?
Update
Make sure your new BIOS is named w6330vsp.10g first before you do this. We have different M/B's and mine might be different. Please be careful!!
A:\awfl789_w6330vsp.10g/nbl/py/sn/cc/r/id
This is correct if you saved the new BIOS to a floppy.
I assume no responsibility if you crash your BIOS. It is a touchy mod that may not work. Good Luck if you choose to take my advice.
