Ben721 said:Where in the console and how do I know if I have the console?
It's not in the log. :O
Ben721 said:Alright I think I have to wait to get a gromac then I will be all set because I hear that will update my core to 78 instead of the 65 which it's at now.
Kendan said:
[21:48:22]
[21:48:22] Project: 909 (Run 22, Clone 15, Gen 4)
[21:48:22]
[21:48:22] Assembly optimizations on if available.
[21:48:22] Entering M.D.
[21:48:42] (Starting from checkpoint)
[21:48:42] Protein: p909_vill_str0
[21:48:42]
[21:48:42] Writing local files
[21:48:44] Completed 45000 out of 250000 steps (18)
[21:48:44] Extra SSE boost OK.
It will show in the log, but there might be a problem. It might still only be on the first one when it is turned on. I have to go do something now but I will look into it later tonight
Edit: It looks like it just doesn't say SSE boost on every protein in the log even thoough it is still on
Tismedt said:OK I am beginning to think I'm an idiot. I'm sure this is so easy but I cant do it. I was at the start of a wu so I shut down the client and uninstalled, deleted shortcuts, files and folders. Downloaded the beta 3.25 and clicked the icon. It goes straight to a screen name/ team # page and starts working. I quit proggie click properties to add the flags and there is no target area to change. What Am I doing wrong.
Audioaficionado said:NOTE TO SELF: YOU MUST INSTALL THE REGISTERY KEY INSTALLER AFTER THE SETUP.EXE OR YOU WON'T GET THE GROMACS FLAGS SET IN THE REGISTRY.
