How would you lap a heatsink?
Gxp
Did I say it right? lap the heatsink or was it the processor? I'm new at this. What sort of material do you need to lap and is there guide somewhere I can check it out? Thanks.
You lap the heatsink...it's the easy one.
Some people do lap the suface of the GPU or CPU, but it's more difficult.
Find a flat surface like a good kitchen counter or some thing similar and place a pane of glass on it (maybe 8 in x10 in). A sheet of newspaper under the glass would help avoid scratches to the counter.
Get 2 grits of sand paper, maybe a 200 and 600 grit in full size sheets.
Place the sandpaper rough side up on the glass and sand away to your desired finish.
lapp the heat sink was correct
lapping involves two thing`s flat as possible.... and smooth as possible
materials
12x12 piece of glass
2 pc 600g sand paper
2 pc 800g sand paper
2 pc 1000g sand paper
2 pc1500g sand paper
Lapp the heat sink was correct
lapping involves two things flat as possible.... and smooth as possible
materials
start with the 600 and end up with the 1500 if all has went well the finish will look like a mirror
damit another double post that make`s two this year .......hehe
It works too.When you start lapping ,you can see the parts of the HS surface that are higher than the rest of it.
Just be careful and apply even pressure over the whole HS or one side will be shorter than th other side when you go to clip it on the cpu. Uneven pressure=cracked core.
