Hmm, I never played/experimented with these sort of connections, specially those involving the use of DCHP. Anyways, what distrobution are you using. Try the following rc script from Slackware, I think it should help you configure it. But even I am not sure if it would work, anyways, give it a try
Edit the lines from the place I marked # *** EDIT FROM HERE and stop at # *** END EDIT FROM HERE
Try everything you can with them. If your host assigns you a dynamic ip address, I dont know what you should put inside the IPADDR variable but like I said, try everything. Save this file as anything you want and give it execute permissions and run it, or run it using bash/sh.
#! /bin/sh
# /etc/rc.d/rc.inet1
# This script starts up the base networking system.
# Version:
# @(#)/etc/rc.d/rc.inet1 8.1 Tue May 28 15:27:39 PDT 2002 (pjv)
# Edit these values to set up your first Ethernet card (eth0):
IPADDR="127.0.0.1" # REPLACE with YOUR IP address!
NETMASK="255.255.255.0" # REPLACE with YOUR netmask!
# Or, uncomment the following lines to set up eth0 using DHCP:
USE_DHCP=yes
# If your provider requires a DHCP hostname, uncomment and edit below:
DHCP_HOSTNAME="CCHOSTNUM-A"
# Edit the next line to point to your gateway:
GATEWAY="" # REPLACE with YOUR gateway!
# Edit these values to set up your second Ethernet card (eth1),
# if you have one. Otherwise leave it configured to 127.0.0.1,
# or comment it out, and it will be ignored at boot.
#IPADDR2="127.0.0.1" # REPLACE with YOUR IP address!
#NETMASK2="255.255.255.0" # REPLACE with YOUR netmask!
# Or, uncomment the following lines to set up eth1 using DHCP:
#USE_DHCP2=yes
#DHCP_HOSTNAME2="CCHOSTNUM-A"
# You shouldn't need to edit anything below here.
# Set up the loopback interface:
/sbin/ifconfig lo 127.0.0.1
/sbin/route add -net 127.0.0.0 netmask 255.0.0.0 lo
# Set up the eth0 interface:
if [ "$USE_DHCP" = "yes" ]; then # use DHCP to set everything up:
echo "Attempting to configure eth0 by contacting a DHCP server..."
# Add the -h option to the DHCP hostname:
if [ ! "$DHCP_HOSTNAME" = "" ]; then
DHCP_HOSTNAME="-h $DHCP_HOSTNAME"
fi
/sbin/dhcpcd -t 10 ${DHCP_HOSTNAME} -d eth0
elif [ ! "$IPADDR" = "127.0.0.1" -a ! "$IPADDR" = "" ]; then # set up IP statically:
# Determine broadcast and network addresses from the IP address and netmask:
BROADCAST=`/bin/ipmask $NETMASK $IPADDR | cut -f 1 -d ' '`
NETWORK=`/bin/ipmask $NETMASK $IPADDR | cut -f 2 -d ' '`
# Set up the ethernet card:
echo "Configuring eth0:"
echo "ifconfig eth0 ${IPADDR} broadcast ${BROADCAST} netmask ${NETMASK}"
/sbin/ifconfig eth0 ${IPADDR} broadcast ${BROADCAST} netmask ${NETMASK}
# If that didn't succeed, give the system administrator some hints:
if [ ! $? = 0 ]; then
echo "Your eth0 card was not initialized properly. Here are some reasons why this"
echo "may have happened, and the solutions:"
echo "1. Your kernel does not contain support for your card. Including all the"
echo " network drivers in a Linux kernel can make it too large to even boot, and"
echo " sometimes including extra drivers can cause system hangs. To support your"
echo " ethernet, either edit /etc/rc.d/rc.modules to load the support at boot time,"
echo " or compile and install a kernel that contains support."
echo "2. You don't have an ethernet card, in which case you should run netconfig"
echo " and configure your machine for loopback. (Unless you don't mind seeing this"
echo " error...)"
fi
fi # set up eth0
# Set up the eth1 interface:
if [ "$USE_DHCP2" = "yes" ]; then # use DHCP to set everything up:
echo "Attempting to configure eth1 by contacting a DHCP server..."
if [ ! "$DHCP_HOSTNAME2" = "" ]; then
DHCP_HOSTNAME2="-h $DHCP_HOSTNAME2"
fi
/sbin/dhcpcd -t 10 ${DHCP_HOSTNAME2} -d eth1
elif [ ! "$IPADDR2" = "127.0.0.1" -a ! "$IPADDR2" = "" ]; then # set up IP statically:
BROADCAST2=`/bin/ipmask $NETMASK2 $IPADDR2 | cut -f 1 -d ' '`
NETWORK2=`/bin/ipmask $NETMASK2 $IPADDR2 | cut -f 2 -d ' '`
echo "Configuring eth1:"
echo "ifconfig eth1 ${IPADDR2} broadcast ${BROADCAST2} netmask ${NETMASK2}"
/sbin/ifconfig eth1 ${IPADDR2} broadcast ${BROADCAST2} netmask ${NETMASK2}
echo "Your eth1 card was not initialized properly. Here are some reasons why this"
echo "2. You don't have an ethernet card, in which case you should fix"
echo " /etc/rc.d/rc.inet1 to stop trying to configure eth1. (Unless you don't mind"
echo " seeing this error...)"
fi
fi # set up eth1
# Set up the gateway:
if [ ! "$GATEWAY" = "127.0.0.1" -a ! "$GATEWAY" = "" ]; then
/sbin/route add default gw ${GATEWAY} metric 1
fi
# End of /etc/rc.d/rc.inet1
