Not unless its a "X" chip or extreme chip. For example QX9650 can but Q9650 cannot.![]()
I did not know that. Thanks.
You can see what headroom the ram has in it by pushing further. What is the exact timing and voltages on the ram? If you are at 4-4-4-xx, up it to 5-5-5-xx. But yes, if your memory ratio is 1:1 with FSB then at 400FSB you are at your ram's stock speed.
@ IJ - Sorry I havent replied in this thread... You dont have much headroom left in the ram. At 400Mhz FSB you are at its stock settings at 1:1. Anything else and it will overclock the ram. The ram should have a bit of headroom in it but... it will vary.
@ Money - Im unable to read those links at the office.. sorry. Here is a screenshot of your bios (found by googling link -> http://www.pcstats.com/articleview.cfm?articleid=2173&page=3) you likely have to set that overclock navigator to manual to adjust those settings. CPU Spec voltage I think is your current reading. If not, grab CPUz and boot to windows and its listed in that application. Its honestly best to create your own thread for help so you dont get missed in this massive thread.
@ alek - Do you have a question about that? If you do, that is normal but that spread is pretty large. Was there a load on that core by chance? If you stress test the CPU, does that core go UP after 51C? If not, thanks for posting that information?![]()
Thanks again for the feedback!
Best regards,
Mike Lynch
Overclocking a Gateway Profile 6.0(P4) or 6.5(E6500)?
I am a novice!
I searched for the "best place / thread" to begin learning.
Is this the right "place"?
If so, I have several initial questions.
If not, please refer me to a more appropriate thread.
I have two stock Gateway Systems which I would like to learn on.
Perhaps they are overclockable or perhaps they are not.
How does one tell?
If they are, my novitiate logic tells me to first upgrade the CPU to the fastest CPU that will run on the Motherboard.
Is this correct?
How does one tell if a faster CPU will run on a Motherboard?
Once completing this potential upgrade, one would then begin the Overclocking process.
Is this correct?
Best regards,
Mike Lynch
Ai Overclock Tuner [Manual]
OC From CPU Level Up [Auto]
CPU Ratio Setting [09.0]
FSB Strap to North Bridge [333]
FSB Frequency [445]
PCIE Frequency [105]
DRAM Frequency [DDR2-1116MHz]
DRAM Command Rate [2N]
DRAM CMD Skew on Channal A [auto]
DRAM CMD Skew on Channal B [auto]
DRAM CLK Skew on Channal A [auto]
DRAM CLK Skew on Channal B [auto]
DRAM Timing Control [Manual]
1st Information
CAS# Latency [5]
RAS# to CAS# Delay [5]
RAS# PRE Time [5]
RAS# ACT Time [15]
RAS# to RAS# Delay [auto]
REF Cycle Time [Auto (52)]
WRITE Recovery Time [auto]
READ to PRE Time [auto]
2nd Information
READ to WRITE Delay (S/D) [auto]
WRITE to READ Delay (S) [auto]
WRITE to READ Delay (D) [auto]
READ to READ Delay (S) [auto]
READ to READ Delay (D) [auto]
WRITE to WRITE Delay (S) [auto]
WRITE to WRITE Delay (D) [auto]
3rd Information
WRITE to PRE Delay [13] -----------> a-data recommendation
READ to PRE Delay [auto]
PRE to PRE Delay [auto]
ALL PRE to ACT Delay [auto]
ALL PRE to REF Delay [auto]
Refresh Period [auto]
DRAM Static Read Control [Disabled]
Ai Clock Twister [auto]
Ai Transaction Booster [auto]
CPU Voltage [1.4750v]
CPU PLL Voltage [1.62v]
North Bridge Voltage [1.59v]
DRAM Voltage [2.38v]
FSB Termination Voltage [1.58v]
South Bridge Voltage [1.125v]
SB 1,5V Voltage [1.60v]
Loadline Calibration [Enabled]
CPU GTL Voltage Reference [0.63x]
NB GTL Voltage Reference [0.67x]
DRAM Controller Voltage REF [Auto]
DRAM Channel A Voltage REF [Auto]
DRAM Channel B Voltage REF [Auto]
CPU Spread Spectrum [Disabled]
PCIE Spred Spectrum [Disabled]
Cpu Clock Skew [auto]
NB Clock Skew [auto]
*CPU Settings*
CPU Ratio Settings [09.0]
C1E Support [Disabled]
CPU TM Function [Disabled]
Vanderpool Technology [Enabled]
Execute Disabled Bit [Disabled]
Max CPUID Value Limit [Disabled]
