This system has a Core 2 Duo E6300 (1.86 Ghz), 2 GiB of DDR2, 320 GiB HDD,365 Watt PSU. I only use it for work projects.
The big issue w/it is that if I go to websites of any complexity and firefox eats up more than a GiB of memory the system begins swapping (i.e. to the swapfile partition), CPU usage skyrockets and the system becomes unusable.
Would it be worth it to upgrade the memory to 8 GiB of DDR2? I'm not even sure if this system even supports 2 GiB
DDR2 DIMM's. The HP manual says it supports up to 8 GiB of DDR2 so it has to support 2 GiB DIMM's right?
