Little brother got nailed at Computer Expo. He spent $700 for a celeron 900 mhz with 128 megs of ram. I haven't had time to check out the specs such as the power supply or the chipset on the motherboard etc, but I was wondering if you folks could suggest some things to do to improve the performance of this thing. He paid too much for this thing considering the other options out there. I'll get more specs when I can later. All I know now is it has 900 mhz celeron, 30 gig hd, 17" monitor, polk audio speakers, 128 mb ram. It's an HP 7XX? I'll try to get more specific info when I get back from an errand I have to run right now...
I know the first thing to do would be to improve the RAM and at least give it 256 to 512 megs so it has a little room to breathe. I am thinking that he could get a different celly chip and install it (start out with a 1.2 instead of a 900 mgz) and then overclock it after installing a better heat synch and fans. I guess I could try the 900 mgz chip first, but why try to gain 30% just to get to the 1.2 when you can get the 1.2 and go from there...
Thanks to all who respond. Any help would be immensely appreciated.
