- Nov 16, 2004
I'm not sure where this should really be posted as it is a combination of OS/Storage/Laptop issue.
I just got an HP Zbook 14" G2 on Friday.
My goal was to install Windows 7 on the laptop using UEFI.
It comes with Windows 7 Pro installed in legacy mode, but I figured I should be able to find a way to get it installed with UEFI enabled so I can eventually dual boot on another drive to Win 10.
It has a 256 GB SSD HP Z Turbo Drive (M.2 PCIe) and I installed an extra Samsung EVO 850 Pro to be available for Win 10.
After going into the BIOS and setting it to UEFI Native (No CSM), disabling Fast boot, and checking other various settings I cannot get this laptop to recognize ANY USB drive I plug into it with UEFI enabled.
I have formatted various USB 3.0 and 2.0 drives using Rufus and DiskPart - They are all obviously FAT32 and formatted using a GPT partition. I even tried using a Win10 installer that worked flawlessly for installing UEFI Win10 on an HP Spectre x360 - and for whatever reason this laptop refuses to acknowledge it as a boot option.
I have also done the necessary steps for preparing the Windows 7 installation media to be UEFI ready.
Now the kicker is that there is an option in the "Boot Options" too boot from an .efi file and it allows me to browse through the directories on these flash drives.
I tried to just select bootx64.efi, but that doesn't work - probably because the Windows Installer isn't meant to initialize that way and I had a feeling that would be the case.
I did A LOT of googling the last two days and I just can't seem to find the caveat here. I'm getting to the point where I feel like I just need to accept that this laptop model was behind the curve and won't read USB drives set up for UEFI. I saw several threads on the HP forums where people cannot even get their Zbook to read CD/DVDs when set for UEFI.
Anybody here have any experience with this that might have a trick or two up their sleeves? I'd greatly appreciate any help!
Edit: I should add I did a BIOS update first thing and it actually reverted back from 1.15 to 1.14.
Edit#2: Updated BIOS to 1.16 from HP's website. Still no luck.
