hsf for a Celeron 600?
drowned
I just ordered the processor, and I need a good hsf for it. What are your opinions on the best?
Fink
I use an FOP-38 without the vaccum cleaner sounding Delta fan. Works great.
ken257
Senior Member
I have used Alpha pal 6035's on Celeron 1/2 and P3's and it works great. Right now I am running a P3-866 at 1007 with an Alpha. The stock fan cools fine so there is no need to put up with a Delta jet engine.......unless you run AMD Just make sure you have good airflow through the case. I have an 80mm lower front and another behind the cpu and have no probs with that.
SickBoy
Inactive Moderator
Minneapolis, MN
I'd say a PEP66 or a PAL6035, maybe a WBK38 modded with an 80MM fan. If you're looking to spend more, the CAK38 and other all copper sinks are nice too.
SickBoy
