I posted this over on AVS, but I thought I'd get input from my pals here at home (OCF ).
Throwing my build at you guys to make sure I'm up to date with my choices. This is a slightly modified (for maximum silence) version of the low end ATX Intel/nVidia posted on page 85 (AVS HTPC build thread).
Core Unit:
Motherboard: EVGA 113-YW-E115-TR $119 ($20 rebate by 3/31/09 = $99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188035
CPU: Intel Pentium Dual Core 2.50ghz Wolfdale E5200 $69
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
RAM: A-Data 2x1GB DDR2-800 ADQVE1A16K $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
HD: Maxtor 250GB SATA (Already own)
PSU: Nexus Value 430W (11db silent) $89 (#1 @ SPCR)
http://www.eastluna.com/hardware/details.php?id=3498&id2=b
CASE: SilverStone Lascala LC17 SST-LC17B $119
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163055
FANS: NEXUS REAL SILENT CASE FAN SP802512L-03 80mm (qty 2) $15.00 each (#1 @ SPCR)
http://www.eastluna.com/hardware/details.php?id=0344
Totaling $430.99
May add:
Blu-Ray: LITE-ON iHES206-08 $119
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106277
Supposed to be quietest BD out, but not many reviews mention loudness and SPCR doesn't do optical drives for some reason.
I will be building a large 16-20 drive server based on the Norco 4020 case for storage so 250GB should be plenty for the HTPC since I do not plan to do any recording, only viewing, which will be streamed from the server, of course.
Only question I still have lingering is about audio. I'm a big audiophile when it comes to 2 channel (music), but I haven't done the multichannel theater thing since DTS (yeah the original) wasn't even out yet so I'm lost with all the new formats. To get the most out of BluRay discs what format do I need and will the above system perform it? If not what sound card do I need to get? I don't yet have my audio path planned so this is open ended.
One last topic is networking. I obviously will be using gigabit lan, but wondered if wireless N is good enough for streaming blu-ray level content. Less wires is always a good thing, but will do so if necessary. The downside to wires is I don't own the house I'm living in so I can't do anything permanent so wireless would be great since I'll put the Norco 4020 server in my spare room due to noise.
Thanks!
Core Unit:
Totaling $430.99
May add:
Thanks!
