Hub or Switch ?
NEWBIE911
NE. from The IE
I have two routers Netgear RT314..... Siemens SS2614 is there a way i can hook them up together .... or do i need a hub or switch.
Both of the routers have 4 ports...... I have 5 computers I want to hook all 5 of them up to the cable modem... All my computers run winxp pro.
xtrmeocr
take one and turn off all the router funtions you can then just hook it up to the other one with a LAN port, should function just like a switch then
