I'm running a homemade watercooling setup, and I seem to have run into a bit of trouble:
-At idle, my cpu temps are 44/45c (as reported by MBM5) while my water temp is generally around 26/27c (PC has been on for the past 24 hours).
Some quick info about the setup:
-I know for a fact that there's very good flow going through. (Eheim 1048 going full blast)
-The block is lapped with 1500 grit sandpaper and is EXTREMELY flat (I used my fathers lapping machine with a 40 micron silica solution)
-I've got Arctic Silver II applied as a thermal compound (in a thin layer because of the mirror finish)
-The waterblock is seated on reasonably firm via screw/wingnut system...probably over the 15-24 lbs limit it's supposed to be at
-The cpu goes from 21c -> 44c in about 5 minutes after I boot up.
-The waterblock is of the copper cap variety
The only real thought I have in my mind is that somehow my previous hsf, the GlobalWin FOP32-I, which had a very rough base, somehow scratched the die/was misaligned and screwed up the die seating, and now I'm not getting good contact.
Any thoughts? I'm stuck.
Thanks in advance
Thanks in advance
